when changing your rearend ............
Old Mar 23, 2003 | 06:35 PM
last of the Z28's's Avatar
Default when changing your rearend ............
when going from a 10 bolt to a moser 12 bolt or a nine inch do you have to change the length of your driveshaft? or the size of your u-joints? thanks
Old Mar 23, 2003 | 08:18 PM
SPANKY LS1's Avatar
Default Re: when changing your rearend ............
The driveshaft length is the same as stock, if you have a 1310 yoke, you can use a stock u-joint, if you have a 1350 yoke, you will need a conversion u-joint (I used Napa #447). Shawn
Old Mar 23, 2003 | 09:45 PM
will that conversion u joint fit in the stock driveshaft? thanks. im asking because i got a carbon fiber and want to make sure i dont bone myself in the long run.
