How tight does the diffy need to be??
Old Mar 26, 2003 | 05:20 PM
Skinny's Avatar
Default How tight does the diffy need to be??
I'm almost done putting in my 3.73s. I had to use EVERY carrier shim my install kit had to keep the diff tight. I had to tap the last shim in with a hammer, but I can still pull the diff out with a tug. Should it take a claw hammer and a bottle jack to get it out? Should I buy some more shims?
Old Mar 26, 2003 | 07:13 PM
rodent's Avatar
Default Re: How tight does the diffy need to be??
"set the carrier bearing preload as tight as you can get it without damaging the shims during installation"
http://www.ring-pinion.com/gear/g0798.shtml
