12 bolt diff cover questions
Old May 22, 2008 | 09:42 AM
sedanman's Avatar
Default 12 bolt diff cover questions
I purchased a 12 bolt but it has no diff cover and I am trying to decide weather or not I need to drop the $150 for a TA Girdle or $25 for a cheap cover.
How much of a advantage is the Girdle?
Old May 22, 2008 | 11:06 AM
Jawsgear's Avatar
Depends on usage. If you are shock loading the differential the TA cover preloads the caps to keep them from deflecting. Plus it also lets heat out of the differential due to it being aluminum.
Jeff
Old May 22, 2008 | 11:17 AM
sedanman's Avatar
Well its a 6spd car I plan to make 450rwhp motor and spray a 150-200 shot. The car susp when dialed in should make it hook pretty hard. Is one Girdle better then another? Or just get a good one with a drain and fill?
Old May 22, 2008 | 11:21 AM
Jawsgear's Avatar
We like the TA brand the best. They are the originator's of that style of cover. Just our preference though.
Jeff
