Rear End Noise
2000 TA, M6, stock 10 bolt, I do have TCS, 41500, I bought used from Original Owner at 29000, WITH aftermarket gear (3:73) already installed. Upon purchase the rear end has always had a whine to it,,,the whine would "bounce" slightly when hitting freeway bumps, etc, nothing that sounded scary.
3/07, had a leaky pinion seal changed,,, fluid all over the place
7/07, B4 hitting the 600 mile drive to and back to the 07 TA Nats in Dayton OH, i had my local Chevy dealer "inspect" my gears to be sure we would be safe on our drive,,everything checked out great, cleance was good on the ring and pinion, teeth looked good, even the oil looked ok..
1/08 I installed headers and gave the car a good couple of runs ,,you know,,,fer fun..also noticed the pinion seal was leaking again during the install
3/08, B4 the 1 year warrenty on my leaky pinion seal expired, i took it in for the fix again.
4/08, slight clicking noice from *** end starts up,,,(i do not DD my TA, so maybe 200 miles from March?),,normal whining noise seems more pronounced, on the highway, esp goin uphill, seems like a low end humming of sorts at speeds of 65 or more....when your slowing down (netrual or not) the humming turns to a clicking, even pulling in the garage, its there, goes slower as the car goes slower,,,like i gotta baseball card pinned to slap my spokes on a bike or something,,,but only a deeper tapping,,,
Today, (5/26/08), debating if i should even start to tear off the cover and look inside,,(i have never performed any rearend surgery myself, although am proficent with, and have the tools needed),,car is in the air, and thats where im at.....any suggestions to what steps to take or what to look for,,im open to any help given to me.
Thanx all
Wayne
any wisdom would be greatly appreciated..
mine makes an awkward sound noise only when WOT from a stop or slow roll. when did yours make a noise?
Mine seems fine until i get going (id say 30 or more) then it dosnt stop until i park it.
i dont see anything funny in my diff,,,,so,,,,bad yoke?, bad driveshaft?, bad u joints? I have no idea, and thought i would get a few pointers from here, but guess not.
Good luck with yours man
Wayne
broken pinion tooth is the cause
ugh
i have never done a gear install b4, but believe i may be givin it a shot
if anyone has any tips to share, plz let me know. I will be doing the bearings and such while im in there,,and will be purchasing the needed tools i dont have for it,,,dial indicator (someone said harbor freight?) and some kind of bearing press....
ugh
ugh
ugh
GL
i dont race or anything i bought the car with this noise so idk how the guy before me treated it. the engine, interior, paint, are in mint condition. dont know about the rear though
