273 to 342??
Old Aug 12, 2003 | 03:19 PM
01Z0H6's Avatar
Default 273 to 342??
Found some 342 gears. Question is, what "exactly" do i need to do/have to make this swap successful!
Also, what kind of $$$ are we talking about? In general? TIA.......... Matt.
Old Aug 12, 2003 | 06:47 PM
OctaneZ28's Avatar
Default Re: 273 to 342??
You're gonna need a new differential in addition to the ring & pinion gears.
2.73 = 2 series diff
3.42 = 3 series diff
And depending on the mileage on the car, you may also need an installation kit, which typically costs $100-120.
Old Aug 13, 2003 | 09:42 AM
Ragtop 99's Avatar
BTW, used gears are more likely to whine than new gears depending upon the wear pattern.
Old Aug 13, 2003 | 11:00 AM
Fast Eddie's 02 T/A vert.'s Avatar
I went from 2.73 to 3.42 without changing the carrier,just make sure the 3.42 gear is a thick gear and you should be alright.
