Is a solid pinion spacer worthwhile for a stock 10-bolt??
anyway, if you're building it, it's a pain in the butt to get the drag set correctly. just one long process of adding and removing shims. but other than that, it's still gonna break
Here is the best part of the whole deal. I used the POS pinion seal from the install kit. The damn thing leaks!!! I have to remove the seal & replace it. Now I don't have to worry about pinion bearing preload as I would've with a crush sleeve installed. That right there makes it worth it for me. Just my 2 cents...
