I need info help asap!!!
Old Jun 24, 2008 | 11:11 PM
soloman369's Avatar
Exclamation I need info help asap!!!
OK well we got dne wit the setup in mt bros 06 crew cab 1500 it has a 6.0 swap cam heads etc first tha tranny went out so we got it redone and bulit just whn we thought everything is ok we played arond a bit and we drive shaft broke in two but where it broke it it also broke the mount for it in the rear can u buy that or do u have too take it to some one? if so where? plzhelp me
Old Jun 25, 2008 | 04:54 AM
EPP's Avatar
EPP
Look in your local yellow pages to see if you have any shops that specialize in driveshafts. We have a local shop that specializes in clutches and driveshafts, they are fairly common.
You could also call PST in Clearwater, Florida to see if they can make you a bullet proof one. http://www.pstds.com/ Bob
Old Jun 25, 2008 | 10:37 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
pinion yoke should be available, but maybe GM only part... you can try a driveline specialty shop like Randy's R&P for a possible upgraded version. what rearend is in the truck?
a PST alum or Strange CM shaft will be a wise choice. i would not consider another stock type. the entire assy should be upgraded to 1350 u-joints... driveshaft, trans yoke, and rear yoke. this should hold up to your engine swap then.
Old Jun 25, 2008 | 10:42 PM
soloman369's Avatar
stock rear end wit 4.10s
