B&M Tranny Fluid
Old Apr 18, 2003 | 11:14 PM
RJF's Avatar
RJF
Default B&M Tranny Fluid
Hi all I was wondering if anyone here uses B&M Tranny Fluid I got it from advanced auto Let me know. Thanks
Old Apr 18, 2003 | 11:41 PM
trackbird's Avatar
Default Re: B&M Tranny Fluid
https://ls1tech.com/ubb/ultimatebb.p...c;f=2;t=007062
It is decent stuff. I prefer to only run it in older automatics (turbo 350/400, ect). One thing that B&M used to state was not to run this in a trans with a lock up convertor. The extra lubricity of the oil could cause the lock up clutch to slip. I'm not sure if that warning is still on the bottle, but I stick to Mobile 1 and Redline if I want better fluid. Good luck!
Old Apr 19, 2003 | 09:09 PM
DrkPhx's Avatar
I assume you mean the new B&M Fluid specifically for late models (Dextron III approved). I'm curious also.
Old Apr 20, 2003 | 09:25 PM
trackbird's Avatar
This came from the B&M website....
http://www.bmracing.com/
Based on this, I'd not try it....
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Trick Shift was originally developed by B&M for racing applications. It has become so successful that it's the most popular high performance fluid on the street also! Not an additive, this is the best performance ATF available! A scientific blend of foam inhibitors, pressure agents and shift modifiers that will provide extended transmission life and drastically improved shift feel. Trick Shift is the easiest way to measurably improve the transmission performance of your vehicle. Trick Shift works with all automatic transmissions* when a firmer shift is desired. 'Pour in Performance' is not just a catchy phrase - it's reality! It can be mixed with stock-type transmission fluids, however to attain maximum improvement you should use Trick Shift exclusively. Ideal for towing, light trucks and RV applications as well as racing. *Not recommended for electronic controlled transmissions. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Apr 20, 2003 | 11:32 PM
DrkPhx's Avatar
That's the old Trick Shift. There is a newer version that is synthetic, Dextron III approved for late-model transmissions. It runs $7.95-qt.
Old Apr 21, 2003 | 12:52 AM
RJF's Avatar
RJF
Its the B&M trick shift TTT Anyone else
Old Apr 21, 2003 | 07:02 AM
trackbird's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Its the B&M trick shift TTT Anyone else
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Trickshift is what I thought he was asking about....The new stuff is likely just fine to use....but I'd not use trickshift....
