Just ordered a 9".....
1)Moser 9" and 31 spline axle package with LCA relocators.
2)Strange Pro Nodular iron case with HD pinion support(not the std), chromemoly yoke, True Trac and Motive (Hi Perf, not the standard) 3.70 gears, 1/2" studs
3) Strange chromemoly 3.5" drive shaft w/ 1350s u-joints and chromemoly front slip yoke.
I got the entire package shipped for $2950. They are even gonna install it, setup the pinion angle and align it for another $250 since I bought it from them. Not bad at all.
I went with the Strange 3rd member setup because of all the stories of gear whine from Moser. These guys told me if it whines, bring it back and they will send it back to Strange and work the repair on their end. Pretty good service it seems, plus they are local so if I have problems, I can take it there and let them listen to it etc.
Once I break it in, I should be able to get my old hooptie to the track and see what it really does on some real tires.
That was my A+ G-Force gear install and setup that they didn't even use a dial indicator on.....
