What fluid to use ?
Old Apr 24, 2003 | 06:44 PM
shane p's Avatar
Default What fluid to use ?
I am getting ready to bench bleed master cylinder and was wandering what fluid to use and the best way to bleed the set up. I have a spec clutch adj master cylinder and mcloud slave in car.I was going to bench bleed the master and then bleed slave because it is in the car and dont want to take it out. thanks for any suggestions.
Old Apr 24, 2003 | 11:57 PM
trackbird's Avatar
Default Re: What fluid to use ?
I've always used dot 4 brake fluid in all of my cars with hydraulic clutches. Good luck.
