Moser 12 bolt
Old Sep 1, 2003 | 09:56 PM
HPCAMSS's Avatar
Default Moser 12 bolt
I recently installed a 12 bolt Moser on my 02 SS....now for those who have put moser .....how did u get the sway bar back in there...did u have to buy new u-joints for the sway bar?......or did u have to buy a diffrent sway bar?.....im driving without a sway bar and it suckksssssssssss ....hellppppppppp
Old Sep 1, 2003 | 10:17 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Default Re: Moser 12 bolt
Check out this month's Chevy High Performance Magazine...
"the sway bar mounting brackets had to be redesigned, as they wouldn't fit on the larger 3-inch axletubes. Detroit Speedworks modifies 3-inch brackets and Energy Suspension bushings to fit the larger-diameter axletubes when it performs such swaps."
But earlier in the article they point out... "the stock rear-stabilizer-bar mounts won't fit, but 3- or 3.5-inch muffler clamps will usually do the trick."
By the way, were you able to use your stock driveshaft?
Old Sep 1, 2003 | 10:26 PM
HPCAMSS's Avatar
thanx, ill go looking for those muffler clamps .....hopefully thatll work.....and on my driveshaft i just had to changed u-joints to fit the bigger 12bolt yoke....but other than that havent had problems with the driveshaft
Old Sep 1, 2003 | 10:32 PM
!LS1 11 Second Club
cool.
Old Sep 1, 2003 | 10:36 PM
JLMoses's Avatar
will I be looking at havin this problem with a 2001 Z-28? just wonderin...with the sway bar and all...I'm orderin my 12 bolt tomorrow..thanks for any help
Old Sep 1, 2003 | 10:40 PM
HPCAMSS's Avatar
i would say yeah your gonna run into the same problem with the sway bar and all
