guys with spools
Old Sep 17, 2008 | 06:29 PM
98mysticZ's Avatar
Default guys with spools
how many miles are your driving a year on your 9's or 12bolts? any problems yet?
Old Sep 17, 2008 | 11:07 PM
DTB_LS1's Avatar
Good question, I would like to know also.
Old Sep 18, 2008 | 08:55 AM
98mysticZ's Avatar
for the morning group
this is the e-mail i sent to eaton
"i am going to be getting a 9inch put into my 98 camaro and was wondering
about the true track diff..... what is the power holding abbility of
this carrier..... i am talkin dumping the clutch at 5500 with a 700rwhp
3900lb car"
and this is what i got back
Dear Mr. Cook,
Thank you for your interest in Eaton differentials. Even though the
Truetrac is the strongest limited slip available for the Ford 9" axle,
for your application you will need a Detroit Locker. Most of the reason
is that I do not think that a 31 spline axle shaft will last in your
case. And the (besides a spool) the Detroit Locker is the only
mechanical differential available for 35 spline axles.
Regards,
Barney Gwozdz
Sales Coordinator / Technical Specialist
Eaton Performance Products
Old Sep 18, 2008 | 09:38 AM
ndfrsd6's Avatar
the spool has the least amount of parts to break ...and if your not driving that much any more than just get .. i think you said you were not driving at much in another post right ..so don't worry about it
Old Sep 18, 2008 | 11:33 AM
Jawsgear's Avatar
Noice he said the axles are the week link. Are you running stock axles or aftermarket because I can give you strength numbers all day long on a set of 31 spline Moser Axles.
Jeff
