Stock 10bolt Rearend Specs
I cannot find the torque specs for the rear end main caps, that little 8mm bolt and cover i think is for 25ft lbs? please let me know as i will be searching away while i wait for responce.
Found this for you, states the main caps should be 65 ft./lbs if you read the entire install, also if I remember right the cover bolts are 18-20 ft./lbs
https://ls1tech.com/forums/showthrea...1#post10144570
