Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
odometer / speedometer same part?
Old Aug 24, 2011 | 07:34 AM
nosliw's Avatar
Default odometer / speedometer same part?
hey
I would like to know if in the 5th generation the odometer gear and speedometer gear are the same part?
are they located in the transmission linked to the dashboard with a cable ?
Old Aug 24, 2011 | 07:21 PM
DietCoke's Avatar
There is no gear for the odo. It's all electronic.
They work seperately. You can unhook the speedo and your odo will still tick.
Old Aug 25, 2011 | 02:29 PM
nosliw's Avatar
Question
ok so where it tooks the speed ? in the transmission ?
Old Aug 25, 2011 | 07:24 PM
DietCoke's Avatar
It's recorded in the BCM and broadcast to the display on the cluster. Its a combination of the VSS in the trans, and the abs sensors at the wheels, and is tied into the tune of the car.
