V6 different from a v8?
its a v6 lt package. manual transmission.. real basic.
I was thinking of dropping an iron 6.0 with ls3 top end and eventually making a "zl1" clone of it.
are the rear end cradles the same? i assume gearing is different but id be putting like 3.73s is it any how.
also i assume the clutch would need to be beefier.. but would the transmissions be the same in a v6 compared to a v8?
also did any changes occur from 2010-2013?
i tried a search but google and wiki arent being helpful
If you have any other questions on the suspension or chassis of these cars I would be more than happy to answer them for you.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
I am aiming for 600rwhp so im not sure how the stock rear cradle would go under that abuse (even on street tires) i still have a lot of researching to do,
as for the front engine cradle, is that the same? could i simply remove the v6 and drop the v8 in there.
do i need v8 motor mounts?
are the v6 and v8 manual transmissions the same?
