Sale on everything
LIFETIME WARRANTY
Fits 2005-2013 GM LS2/LS7/LS3 Cars
Direct OEM replacement, exceeds OEM specifications, OBD-II computer safe
0 Ohm resistance
Patented* design
Solid stainless connector cable with stainless snap lock spark plug connectors, unique EMI/RMI protection ring
The only true solid stainless steel core wire that works with today’s computer dependant engine and all race cars
No RFI / EMI issues – works with any fuel injection / No stereo noise
Increase power to the spark plug up to 400% over stock
Improves mileage and throttle response
High temperature silicone boots, 8MM jacket with fiberglass-reinforced
braid with fire sleeves resists temperatures up to 1200 degrees f
Ideal for use with aftermarket headers and turbocharger systems
Includes all necessary hardware
* Granatelli O ohm wires are patent protected by United States Patent number 7,185,622. This patent covers our unique method of producing ignition wires of extremely low resistance while maintaining very high noise suppression. The benefit of this invention is that full electrical energy from the ignition source is transmitted to the spark plug. The end result of the application of this method is increased horsepower, torque and fuel economy.
Camaro 1G Suspension Bracing Package
came come is any color
Camaro Rear Lower Control Arms
Camaro Adjustable Toe Link (also comes in RED)
Chevrolet Camaro Lowering Spring Kit
Drops front of the Camaro 1.125"
- Drops rear of the Camaro 1"
Fits 2010-Present Camaros
Direct OEM replacement, won't void your factory warranty
No obnoxious sound or drone
T-304 stainless steel
Polished 4” tips with rolled edges
100% complete, bolts-on in about 1-hour with no welding
Louder System
PM FOR PRICES
G-Load Brace
MAF Sensor
Valve Covers
LS1 & LS6 Cars Coil-Near-Plug Conn Kit
2010-2013 Camaro Twin Turbo Kit
2010 - 2013 Camaro 1G Suspension Bracing Package
2010 - 2013 Camaro LS2 LS3 L99 Cat Back Exhaust
2010 - 2011 Camaro Performance Stainless Steel Headers
2005-2013 GM LS2, LS3, LS7, LS9, LSA, L92, L99, L76 80KV Coil Pack
2010-2013 Camaro Cold Air Intake system
2010-2013 Camaro Pro Stock Look Wing
2010 - 2013 Camaro LS2 LS3 L99 Axle Back Exhaust
2005-2013 LS2/LS7/LS3 Cars Coil-Near-Plug Conn Kit
