2014 SS Camaro engine package??
Old Dec 8, 2014 | 06:59 AM
allshotout's Avatar
Question 2014 SS Camaro engine package??
Been looking at some different FI options. But also thinking about heads, cam, intake may be a good route and simple. Anyone have experience with head swap and can recommend a combination that works well. In my past Ford life ran a 10.5" tire car, an ran AFR heads which worked well on my combo. Car is currently factory except CAI and HQ Coilovers. Thanks for any info.
Old Dec 10, 2014 | 05:45 AM
motion427's Avatar
Quite a few FI options out there.
If you want something different but can make big power with easy.Take a look at AGP twin turbo system.(bolt on,but takes a little time). I think the easiest supercharger to install is the SLP.
Whipple,Procharger,ECS,Edelbrocks,Manuson,etc..... plenty of options.....
Hellion came out with a top mount twin turbo kit not 2 long ago aswell...
Once you decide which way you want to go with F/I then check with Brian Tooley racing. He can set you up with a nice set of Trick Flow heads,custom cam & valvetrain. Some other good people here for cams are Tick Performance and Pat G.
Depends on your location,you might find the right parts in your back yard.lol...
Old Dec 10, 2014 | 06:23 AM
nancygrl's Avatar
When I had my '11 SS, I had 20x9.5" wheels up front and 20x11" wheels in the rear. Just need to make sure you get wheels with the correct offsets and it will look awesome.
Old Dec 22, 2014 | 05:57 PM
1KillerSS's Avatar
I researched different FI options since I first bought my car. I am installing AGP's TT kit, and some other things. Car should be done Jan 15th. Can't wait to get it back!
I thought about doing heads but to be honest I am already way over budget on my build so I decided against it. Can always just turn up the boost!! lol
