Buy used ls3
I'm looking at buying an ls3 with 35000km on it when it was pulled about 8 years ago...been sitting for all that time indoors.
anything I should be looking for when I go check it out ?
Have a bore scope handy and pull the spark plugs to inspect the bores and pistons. Also turn the engine over by hand to make sure it's not seized up. LS3's have 6.2L stamped on the front of the block and came with 821 casting cylinder heads which had the hollow stem intake valves.
