Gen 5 Camaro Power-Adder Tech Supercharger, Turbo, Nitrous
Almost there!!!
Old Apr 4, 2014 | 06:45 PM
BullF-16's Avatar
Default Almost there!!!
Its been 2 1/2 months and I can finally see the light at the end of the proverbial tunnel.
I Just picked up my hotside and part of the cold side parts from my coater (Specialized Performance Coatings) in Arlington. Install starts Monday and some final fabrication on the compressors to FMIC tubing. Install of steering column gauge pod and Autometer fuel press gauge and Boost Leash boost by gear boot controller. Hopefully tune starts before the end of the week. Looking at 20 psi with 8# waste gate springs.
I loathe big cities BTW
Attached Thumbnails Almost there!!!-img_0786.jpg   Almost there!!!-img_0787.jpg   Almost there!!!-img_0788.jpg
Old Apr 5, 2014 | 08:05 AM
nyny10-ss's Avatar
Good Luck
Old Apr 5, 2014 | 11:57 AM
epstein's Avatar
What numbers you shooting for? PSI... Torque.... Hp... 1/4 mi?
Old Apr 5, 2014 | 12:06 PM
nyny10-ss's Avatar
I don't think bull is a 1/4 guy. Probably a mile guy though.
Old Apr 5, 2014 | 12:28 PM
ls427ray's Avatar
sounds like big horsepower numbers coming forthwith soon.
Old Apr 5, 2014 | 01:26 PM
BullF-16's Avatar
My shop just completed a couple CTS-Vs running very similar LSX 427 motors with this same custom fabricated setup and they each made over 1300whp and tq. They were at the 1000whp level at only 17-18 psi. This was thru autos, im still an M6
https://ls1tech.com/forums/forced-in...ugh-4l80e.html
Im going to run 8 pound wastegate springs so max boost will be around 20 psi on the BoostLeash controller. That should put me between 1000 and 1100 whp. My calculations also show this power level at this boost..
Im running 93 octane pump gas with a pint of Torco per 15 gallon fillup. Octane in tank is 96. Also running dual meth nozzles.
I could probably go higher but dont want to push it since E85 is not an option here.
Correct, not a 1/4 or 1/8 guy. I've spent 21 years going from 0 to 175 in 2500 feet, so the thrill is just not there on the strip. The mile is out of there also since my gear ratio is at 3.50 and my 19" wheel/tire combo max me out at 185 in 5th gear at 7000rpm. I could add back in the 20inch wheels and tires but would still be below 200.
Car has been setup to tear up the road course with the suspension/brakes/wheels & tires im running.
Its mainly just an overbuilt street car to get the occasional adrenaline rush.
Nah, 1100whp is not that much comparatively speaking. But it should be pretty fun.
Old Apr 10, 2014 | 03:21 PM
Patrick G's Avatar
LS1 Tech Administrator
Looking good Jim. It's gonna be a beast for sure!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 10, 2014 | 04:47 PM
BullF-16's Avatar
Thanks Pat. It should be ready for the dyno mid week next week. James Karger is doing the tune. I hear he is great tuning with meth. I think on pump gas at this level i need to run the meth. I wish I could get E85 way up here.
How do you think the cam you spec'd for my D1SC will do with the twins? May have you spec out another if needed.
 Michael S. Palmer
Old Apr 11, 2014 | 07:26 AM
Slowhawk's Avatar
LS1Tech Sponsor
1000hp sounds good. A dyno pull is easy. Making it last for a 1 mile run is the trick.
Old Apr 11, 2014 | 10:13 AM
BullF-16's Avatar
Im geared too low with my wheel/tire setup to get north of 185 at 7000 om 5th anyway. Plus i have an assload of time on runways and not real interested. road course is what Ive leaned towards. My 8# springs and Boost least should keep it manageable on the track.
The 1100 is for fun on the back roads!
Old Apr 16, 2014 | 04:16 PM
2010SSRSM6's Avatar
Were they able to get the tune completed for you yet Bull?
Old Apr 16, 2014 | 09:30 PM
BullF-16's Avatar
see the previous post
