Gen 5 Camaro Power-Adder Tech Supercharger, Turbo, Nitrous
nitrous help
Old Aug 29, 2016 | 10:34 AM
Tj13ss's Avatar
Default nitrous help
im having some nitrous issues on my 2013 camaro ss. the setup is a nitrous outlet plate, nitrous outlet solenoids, nos 2 stage controller, nx standalone set at 58psi, and lnc2000. i tried spray it this weekend and for some reason when i turned it on in 4th gear it didnt spray it was like it was just dumping fuel. right after that i tried to spray it and it worked perfect in 2nd and 3rd, but when i hit 4th again it fell on its face. the bottle weighed 21lbs before the runs and still had 900+ psi after the runs so i dont think the bottle was low. anyone have any idea what could be causing it to do this?
Old Aug 29, 2016 | 03:36 PM
AJatNitrousOutlet's Avatar
What was your bottle pressure when you started the run?
Old Sep 19, 2016 | 01:29 AM
subeone's Avatar
check for a stuck nitrous solenoid
