Gen 5 Camaro Racing Tech, Results Drag racing, road racing, street racing. Share tech & results!
Launch Control
Old Apr 25, 2010 | 07:43 AM
blk/slvr02ss's Avatar
Default Launch Control
Could anyone explain this too me.I did what the owners manual tells me too do but it did not seem to work.What RPM does the car 2 step @ and does it work @ the track or how should i launch my car on street tires so i dont do 2.33 60ft times.I am not to good w/ a stick car so any help w/ the launch and how to shift the car threw the gears would help.
Old Apr 25, 2010 | 01:32 PM
scottyk246's Avatar
Just hit the traction control button twice and it will go into launch control mode. If I remember correctly you have to be at a dead stop, in first gear, clutch all the way in. Should rev to about 4200 or so and when you dump the clutch it will manage wheel spin.
Old Apr 25, 2010 | 02:46 PM
Bald menace's Avatar
you have to put the gas pedal to the floor quickly. cant slowly press it down from what i have read.
Old Apr 25, 2010 | 04:06 PM
So u say it comes on @ 4200 and that seems a lttle high to me.I dont think i will be using that.
Old Apr 25, 2010 | 06:07 PM
Cole Train's Avatar
The car will be fine just DO IT
Old Apr 25, 2010 | 06:10 PM
Maybe once!!!!!!
Old Apr 25, 2010 | 06:30 PM
djsanchez2's Avatar
Works just fine man.
http://www.youtube.com/watch?v=yPjsi...eature=related
http://www.youtube.com/watch?v=-G6mv...eature=related
Here is a demonstration and tutorial on how to use it
http://www.youtube.com/watch?v=uxvlVtBAZ74
Old Apr 26, 2010 | 06:18 AM
Now do u use the clutch when shifting gears or what do u do too help short throws between gears.
Old Apr 26, 2010 | 09:05 AM
deft's Avatar
dont use launch control at the track. I launch at around 3000 rpm slipping the clutch on stock tires, but I'm making less hp than you. you need to find your sweet spot where you get a little chirp, but it grabs. When throwing the gears, use the clutch, shift quick, but avoiding wheel spin between gears. Try to shift right before your rev limiter kicks in.
Old Apr 26, 2010 | 11:53 AM
DieselNuts's Avatar
wow, those are some slow shifts
you definitely want to use the clutch, but instead of "pressing" the clutch, it's more of a "stabbing" movement. You just want to jab the clutch, bottom the pedal out and release it. In the amount of time it takes you to do that, you should be finding the next gear with your right hand.
Old Jul 14, 2010 | 09:46 PM
walhan_qtr's Avatar
I dont think the LC is useful in these cars... maybe for a stock car MAYBE but other than that I find it really not that useful esp since you cant really adjust the RPM...
here is a vid of my car with bolt-ons and no tune... lots of wheels spin!
http://www.youtube.com/watch?v=fc0P2NxIZ2s
Old Jul 26, 2010 | 11:33 AM
99CamVanillaTop's Avatar
You are probably right, I tried it at the track and it was full of fail.
Old Jul 26, 2010 | 04:32 PM
GatorFan08's Avatar
Too bad you cant raise it to 5000! looks like it bogged down pretty good there
