wheel stud help
Old Mar 22, 2010 | 11:18 PM
treedoc2000's Avatar
Default wheel stud help
I need some help. does anyone know where to locate some longer wheels studs for this camaro SS ?? I have tried jegs and all the local shops and no-one has one to match. I added some aftermarket wheels and with the needed 1/4 inch spacer(to clear brakes) I only have 4.25 turns before the lugnut is tight. Any thoughts or ways to cheat THANKS
Old Mar 23, 2010 | 01:50 PM
Hmmmm NOT GOOD silence
Old Apr 21, 2010 | 11:52 AM
1bad/2ss's Avatar
bump i need help with this also
Old Apr 21, 2010 | 01:20 PM
Jon@Texas-Speed's Avatar
I've been trying to check on this as well. Been coming up empty thus far.
Jon
Old Jul 11, 2010 | 06:58 PM
mwg2600's Avatar
Anybody know what the measurement's are on the factory studs? I could see if i can come up with something.
Old Jul 11, 2010 | 07:18 PM
ghostbird's Avatar
try arp wheel studs they make longer ones
Old Jul 16, 2010 | 04:54 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
I searched and searched for the receipt but came up empty-handed or i would have a part number for you guys. We matched up a stud at Advance Auto parts that worked perfectly. I remember that it fits a 3/4 ton Chevrolet truck but I am unsure of the year. It was a common Dorman part number that they had in stock so just knock one out and run down to your local Napa. They should be able to just look up late model 14mm GM truck studs.
Whoever finds it, make sure you post the part number!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jul 20, 2010 | 11:42 PM
blakss's Avatar
im having the same exact problem and thanks you guys for the info imma try it out.
Old Aug 12, 2010 | 01:20 PM
BMR Tech2's Avatar
Anybody come up with anything yet?
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old Aug 13, 2010 | 06:20 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
M14x1.5x28 threaded. 58 is total length. That is what GM says. Ill get some measurements tomorrow on the knurling for the peeps that still need them. I have some here on hand.
Also FYI, its the same wheel stud used on the Equinox, Lacrosse, '11 Regal, Astro van (03/05), S10 trucks 98-05, full size vans, Full size trucks 99+. Just to name a few.
Old Aug 13, 2010 | 07:04 PM
glasscrew's Avatar
I used ARP wheelstuds when I put I put my weld draglites on and couldn't clear the brakes. So I used spacers but then I was breaking lugstuds so I got ARP wheelstuds. Works good.
Old Aug 14, 2010 | 10:55 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
The wheel doesnt care what size the stud it, the only thing that matters really is the serrated side that goes through the hub. That is all that matters.
