P0054 and P0060
2011 camaro ss L99. Could you please advise, every morning I have check engine related to the active P0054 and P0060 codes. I have both cats-off and ECU was reflashed 1 year ago. Is it internal O2 sensors failure or I need to rewrite ECU again and disable heating function ? If it's a sensor's issue, is it downstream side or upstream ?
Thank you in advance.
PS. Maybe it's a normal in my case, while scanning I always see P0420 and P0430 errors without check engine (constant error)
Is 07 fuse stands for front O2 sensor only or it's shared with the EVAP purge valve ? L99 engine
