Gen 5 Camaro Tuning, Diagnostics, Dyno results Tuning problems, solutions, dyno results for Gen 5 Camaro
P0033 Code
Old Jun 6, 2023 | 07:12 AM
pjm333's Avatar
Default P0033 Code
2013 CamaroZL1 Convertible
P0033 Turbocharger/Supercharger Bypass Valve "A" Control Circuit
Car was off the road on a trickle charger for 5 months and every year I get codes when I put it back on the road. Disconnect the battery and all is well but this year the P0033 code is sticking around.
The car runs & drives fine and looks like its the "Supercharger Bypass valve adjustment" Any help with fixing this code is appreciated. Thanks !
Old Jun 7, 2023 | 01:16 PM
LS1Formulation's Avatar
You might try over on Camaro5, the Gen 5 section here doesn't get much action. I have one, and I don't even post in here, lol. Then again, Camaro5 is kinda dead too, unfortunately.
Old Jun 7, 2023 | 01:31 PM
pjm333's Avatar
I posted there already with no response, so I tried here. Thanks !
Old Jun 7, 2023 | 05:59 PM
Well, here's my take on it - There's a possibility that your bypass is hanging up when opening. Maybe gummed up somehow? I'm not familiar with ZL1 blowers, but I suspect it has an actuator with a 0-5V output and the PCM is not seeing the value it's commanding. You'd have to have it hooked up to a bi-directional scanner and command it open ( if it is in fact operated in this manner ) and see if it will open to the value commanded.
Old Jun 8, 2023 | 05:55 AM
pjm333's Avatar
Thanks for your help, I have a bi-directional scanner and will see what it says. What do you think of this video ? Thanks
Old Jun 25, 2023 | 04:34 AM
pjm333's Avatar
I had to replace the Bypass Regulator Solenoid, code is gone all is well.
Old Jun 27, 2023 | 10:10 AM
Awesome, glad to hear it!
