Cam instal or not?
??? the only way to get to the lifters on a lsx engine is to remove the heads.
if you want a decent cam in a 2010 camaro auto trans , you will need to remove the heads and replace the afm/dod lifters and lifter trays with standard LS2/3 lifters and trays, also you will need to remove the vvt cam gear and replace it with a LS2(3 bolt) set up for the most cam selection and a LS2/3 front timing cover
then get a tune to remove all the afm/dod and vvt from the ecm
i was totally NOT thinking when i posted that! For some reason i was thinking about how every dealership around here tells me that you have to pull the heads to remove the cam. Sorry totally different subject there. Hopefully i wont be flammed to bad for this.... like the guys with MS3 that says its like stock, haha helen keller would call bs on that. drivable and like stock are two VERY different things.
http://www.texas-speed.com/shop/item...=1057&catid=44
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
http://www.texas-speed.com/shop/item...=1057&catid=44[
/QU
Do you have a M6 or auto trans in this one?
I'm betting most the sponsors that do the work will disagree with pretty much everything you have said.
you can disagree but im not entirely wrong. it is you that cant wrap your head around the fact that it is all relevant. i have cartek and ttp in my backyard its not our tunes. id love to hear these "PROPER supporting mods" which improve drivability. its all about trade offs kid.
the sponsor did provide feedback which i appreciate stating that the new more powerful computer helps combat the issues i have brought up.
