[VR] VENGEANCE RACING FALL SPECIALs
Fall is finally here, and we're starting it off with HUGE SAVINGS on parts and service!!!
*Special Pricing for a limited time only. Call to reserve your appointment or place your order today*
VENGEANCE RACING PARTS SPECIALS
*ALL SALES CAN BE FOUND ON OUR ONLINE STORE*
GEN III - LS1 / LS2 / 4.8 / 5.3 / 6.0
SAVE $200.00 on ALL "Build Your Own" Heads/Cam Packages
CATHEDRAL PORT PACKAGES STARTING AT $2,079.99
SAVE $100.00 on Cam Kit + and Budget Cam Kit
VENGEANCE RACING CAM KIT +
Includes: Custom camshaft of your choice, VR dual valve spring kit, hardened pushrods, C5R timing chain, Comp trunion upgrade for OE rockers, Melling hi-volume oil pump, front cover seal and gasket, waterpump gaskets, ARP cam bolts, and GM crank bolt (3-bolt timing gear/LS2 damper available if needed)
VENGEANCE RACING BUDGET CAM KIT
Includes: Custom camshaft of your choice, VR dual valve spring kit, and hardened pushrods
SAVE $50.00 on ALL VR Custom Grind Camshafts
ORIGINALLY $399.99 - NOW ON SALE FOR $349.99!!
PORTED FAST LSXR 102mm Intake Manifolds - Starting at $899.99
UP TO $275.00 IN SAVINGS!!
LS1/2/6 | LS3/L99/L76/L92 | LS7 | LSXRT | 92mm
*FREE* Mounting & Balancing on ALL Wheel & Tire Packages
ORIGINALLY $25 PER WHEEL/TIRE!!
GEN IV - LS3 / LS7 / L99 / L76 / 5.3 / 6.0 / 6.2
SAVE $200.00 on ALL "Build Your Own" Heads/Cam Packages[/SIZE]
LS7 PACKAGES STARTING AT $2,499.99
SQUARE PORT PACKAGES STARTING AT $2,399.99
*FREE* VR Stainless Steel Brake Lines w/ Purchase of SET of Carbotech or Hawk brake pads
*5th Gen Camaro / C6 / C6 Z06 ONLY*
ORIGINALLY AN $89.99 VALUE!!
VENGEANCE RACING INSTALL PACKAGE SPECIALS
C5/C6 Corvette
VR/WCCH LS7 Cylinder Head Exchange Program - $3,699.00 INSTALLED & TUNED
$500.00 value!
Restore confidence and increase performance on your LS7 valvetrain with the Vengeance Racing cylinder head exchange program.
Includes: WCCH Stage II CNC Ported cylinder heads (exchange), dual valve spring kit, head bolts, head gaskets, labor, and tuning
SAVE $250.00 when you purchase any ARH longtube header system with installation!
C5 AND C6 ECS or A&A SUPERCHARGER KITS - INSTALLED & TUNED
STARTING AT $7,499
C7 Corvette
$500 OFF ALL C7 PERFORMANCE PACKAGES
SAVE $250.00 when you purchase any ARH longtube header system with installation! (Cannot be combined with Performance Packages)
4th Gen F-Body
LS1 F-Body BUDGET CAM KIT - $1,799.99!!!
Includes: VR Custom camshaft of your choice, VR dual valve spring kit, hardened pushrods, NGK spark plugs, front cover gasket & seal, fluids, and street tuning
5th Gen Camaro
5th GEN CAMARO ECS SUPERCHARGER KITS - INTALLED & TUNED
STARTING AT $7,999
WHIPPLE SUPERCHARGER SYSTEM FOR 5TH GEN CAMAROS - INSTALLED & TUNED (Whipple Tuner)
STARTING AT$8,999
CTS-V / ZL1
**$500 OFF ALL STAGE IV and STAGE V PERFORMANCE PACKAGES**
**$250 OFF ALL STAGE II and STAGE III PERFORMANCE PACKAGES**
**$100 OFF ALL STAGE I PERFORMANCE PACKAGES**
Trucks / SUVs
PROCHARGER
1999-2003 TRUCK AND SUV - INSTALLED AND TUNED
STARTING AT $6,699
2003-2006 TRUCK AND SUV - INSTALLED AND TUNED
STARTING AT $6,999
2007-2014 4.8/5.3L TRUCK AND SUV - INSTALLED AND TUNED
STARTING AT $6,499
2007-2014 6.2L TRUCK AND SUV - INSTALLED AND TUNED
STARTING AT $6,199
WHIPPLE INDUSTRIES
GEN V 5.3L TRUCKS 2.9 WHIPPLE - INSTALLED & TUNED (Whipple tuner)
STARTING AT $6,699
GEN III & GEN IV 4.8/5.3/6.0/6.2 TRUCKS 2.3 WHIPPLE - INSTALLED & TUNED (Whipple tuner)
STARTING AT $7,499
