General LSX Automobile Discussion Non-technical LSX related topics.
Security system problem. Help!
Old Feb 17, 2011 | 09:05 PM
02_camaroz28's Avatar
Default Security system problem. Help!
So i got my transmission back in my car and got everything hooked up. I hooked up the battery and the alarm started going off. I tried to shut it off with the key fob and it wouldnt work. So i replaced the battery and it still didnt work so im guessing the key fob is broken. In the meantime i cant start my car. Is there anyway i can get around the security system to start the car? Thanks!
Old Feb 18, 2011 | 07:57 AM
Anyone?
Old Feb 18, 2011 | 08:08 AM
wreckwriter's Avatar
Every system is different, some have a little pin pad hidden under dash but you gotta know the PIN.
Old Feb 18, 2011 | 08:59 AM
If I buy a new key fob can i program it in when the alarm is going off?
Old Feb 19, 2011 | 03:15 AM
myk's Avatar
myk
I would....climb in through the car windows, leaving the doors closed (not triggering the alarm), and then try starting the car...
Old Feb 19, 2011 | 12:46 PM
Lol thanks for the suggestion but I got it figured out. Maybe that idea will come in handy some day though.
Old Feb 19, 2011 | 01:32 PM
mentiroso's Avatar
My Viper alarm screwed up one time, would not disarm. Replaced battery in the fob and still nothing so I had to find the disarm button under the steering wheel. All I had to do was turn the key to the "On" position and then hold that button for 3 seconds and then crank the car, after that I have had no problems but if you have a Viper Alarm you can keep that in mind for the future. Seems to work that way on several different Viper models from what I found online but you do have to have that button installed. Some people do not install it so if that is the case you are SOL.
Old Feb 19, 2011 | 03:50 PM
Yeah thats what I ended up doing. It just took me awhile before I figured it out Thanks for the advice though!
