Problems after dash removal
My first thoughts were that it was due to the fact that I pulled both air bags and air bag module, but I connected the module back up and it did not change anything. I have tried two different ignition keys, thinking it was the resistor in the key, but that did not work.
The headlights/brakelights/blinkers/flashers all work, even the blinker lights and high beam indicators in the cluster work, but the fuel pump does not prime and the starter will not even try to bump over.
Any help/ideas would be greatly appreciated. I am at a loss.
Also, if it is plugged in, disconnect it and look at the pins on the switch. Had a car towed to me (similar situation) and the pins were bent/not contacting the wires in the connector.
