General LSX Automobile Discussion Non-technical LSX related topics.
engine jerking?
Old Mar 12, 2011 | 03:18 PM
Michael Crisp's Avatar
Default engine jerking?
at idle my engine is jerking, itll idle for 2 seconds then youll see the engine jerk real hard. what could this be? i have a 98 z28 thanks
Old Mar 12, 2011 | 03:23 PM
ULTIMATEORANGESS's Avatar
any mods?
Old Mar 12, 2011 | 03:27 PM
just installed pace setter long tubes and a tsp catted y pipe
rear o2 sensors arent in, only removed 2 spark plugs and i replaced them
Old Mar 12, 2011 | 03:49 PM
The Mighty Texan's Avatar
Off balance from a cylinder misfire? Motor mounts
Old Mar 12, 2011 | 04:23 PM
its back firing a little bit after the two do-do spark plugs. theres a sensor RIGHT infront of the driver side header, its broken idk how this happend but would that have something to do with it? and it doesnt start up like it should when i turn the key i have to hold it for a good 3-5 seconds for it to fire up
Old Mar 12, 2011 | 05:08 PM
id check for loose wires.
Old Mar 12, 2011 | 05:19 PM
all wires are good (to me atleast)
could the broken coolant temp sensor be the culprit?
