General LSX Automobile Discussion Non-technical LSX related topics.
set-up
Old Sep 20, 2012 | 09:46 PM
02 reaper z28's Avatar
Default set-up
ok guys so i decide this coming tax return to do H/C in my trans am, and i was wondering if this is a good set up to run. Looking to get around 400hp to the wheel. Also is my DD. The car is a 2001 trans am A-4/ full exhaust/3200 stall
springs/push-rods/cam - tsp 228r package
oil pump/timing chain/gear - tsp slp package
lifters - tsp ls7 lifters
243 heads P/P
bosch 42lb injectors
asp UP with alternator pully
would this be a good set-up for a DD and will it give me good numbers?
Old Sep 21, 2012 | 02:21 AM
bww3588's Avatar
I'd look into a 3600 stall, but other than that it looks good. Should be around 420+ at the wheels. A fast 92 or 102 intake should net you another 20 or so over that.
Old Sep 21, 2012 | 10:37 AM
NC98Z's Avatar
I would go with the TV2 instead of the 228 since your running a stalled auto. I ran that combo once and liked it alot. Install a set of 3.73 gears installed in the rear and you'll be screaming down the road.
Old Sep 21, 2012 | 02:03 PM
99Bluz28's Avatar
IMO, or the Comp # 54-446-11(232/234 112+2lsa) virtually the same as a TQ v2 w/112lsa; for less $$$ . The 228/228 or a 228/232 is still a good choice you can't go wrong with in a multipurpose car.
http://www.ws6project.com/user_stor/...-xe-r-232-234/
Old Sep 21, 2012 | 04:42 PM
BOBS99SS's Avatar
Captain Double Post
Custom eps cam/ heads to match, thats what i would do imo
Old Sep 21, 2012 | 06:26 PM
well is between dose two cams a 228r cam or a torquer v2 cam, the thing is that latter on i may swap a lq9 in it and run some boost, i heard that a 228 cam is pretty good on boost.
what would yall run? 228r or v2 cam?
Old Sep 21, 2012 | 11:38 PM
TXZ28LS1's Avatar
I wouldnt go smaller than a 228/228 and probably not any bigger than a 232/234 for a DD fun street car. I would also suggest going with atleast a 3600 converter
Old Sep 22, 2012 | 11:50 AM
MikeWS6's Avatar
The 228R is the biggest I would go on a street car. That cam makes power everywhere. There is no loss of low end power and the car is still streetable.
Old Sep 22, 2012 | 10:06 PM
between the 228r or v2 witch would you guys choice for a DD and hardly to no track time??
Old Sep 23, 2012 | 05:45 AM
99Bluz28's Avatar
With your current stall the 228 with 114lsa.
