General LSX Automobile Discussion Non-technical LSX related topics.
nitrous thru airflow mass
Old Nov 20, 2014 | 06:44 PM
jamalsa's Avatar
Default nitrous thru airflow mass
Is 100 shot safe to spray on a wet system thru the airflow mass.I have nitrous express pn 20110 kit
Old Nov 20, 2014 | 09:41 PM
murphinator's Avatar
Ive sprayed dry shots through a maf sensor many times but don't think a wet shot is a good idea since you would be spraying gasoline through an electrical sensor , just sounds like a bad idea.
Havent sprayed a wet on an f body but i would picture a basic wet shot having a nozzle in a plate between the throttle body and intake manifold above that I would picture direct port with 8 nozzles in the 8 intake runners.
If I am wrong I am sure someone will crucify me err correct me lol
Old Nov 21, 2014 | 08:13 AM
mjs1012's Avatar
For a wet shot you want to put the nozzle in the bellow before the throttle body, where as a dry shot you will do pre MAF. The wet shot already has gas added to it and a dry uses the MAF to add the fuel.
Old Nov 21, 2014 | 11:47 AM
jamalsa's Avatar
okay that's
Old Nov 21, 2014 | 11:50 AM
jamalsa's Avatar
so is it safer to mount it in front of the throttle body instead of spraying thru the tube
Old Nov 21, 2014 | 06:01 PM
mjs1012's Avatar
Yes, you're going to want to put the nozzle in front of the throttle body after the MAF since it's a wet kit.
