General LSX Automobile Discussion Non-technical LSX related topics.
Stumped!
Old Aug 29, 2019 | 09:13 PM
rknight's Avatar
Default Stumped!
Hello. New to this. I have a freshly rebuilt ls2 stroker 402. Runs great. Close to 500 rwhp. Recently it just started acting erratically and shutting off after it gets warmed up. Runs great cool. Can't drive it. It's not overheating . Any suggestions?
Old Aug 30, 2019 | 08:24 AM
cookseyb's Avatar
Check the Tune
Old Aug 30, 2019 | 10:39 AM
bammax's Avatar
Assuming that the engine ran fine at some point and then started acting up, I'd say throw a cheap scan tool on it and watch the front O2 sensors. Usually when an engine only acts up when warm it's O2, vacuum leak or electric fans pulling too much power when they kick on. I've experienced all of these issues over the years in different GMs
Old Aug 30, 2019 | 05:08 PM
rknight's Avatar
Thanks I will check this in the morning. Appreciate it.
Old Nov 1, 2019 | 05:11 PM
rknight's Avatar
Default Ok Still stumped.
Same ls2. Fixed the shutting off problem. Was the header bolts?. New problem. When started idles fine then if hit the gas no matter how much the idle jumps to 2000. Put in gear it drops and back in park stays normal till the gas is pushed again then back to 2000. Any help would be appreciated. Thanks
Old Nov 1, 2019 | 05:21 PM
bammax's Avatar
First area to check is at the throttle body. It could be a bad throttle cable, a bad linkage, sticking blade or something else in that area.
