General LSX Automobile Discussion Non-technical LSX related topics.
Fuel
Old Mar 5, 2022 | 04:06 PM
Yoji h 123's Avatar
Default Fuel
What fuel octane is needed for 8.8:1 compression ratio with boost?
Old Mar 5, 2022 | 07:58 PM
theunderlord's Avatar
Any pump gas available to you will be fine with that low of a compression ratio.
Old Mar 9, 2022 | 07:14 AM
How much boost? Give us a mod list please. More info.
Old Mar 9, 2022 | 08:05 AM
Yoji h 123's Avatar
18 Ibs of boost 195cc cylinder heads and eagle competition forged crankshaft and h beam rods and edelbrock super victor single plane and holley hp efi multi-point 4 barrel 1000cfm and Jesel 1.7 ratio rockers and Jones machine racing products complete accessory drive kit and msd pro billet distributor and total seal custom piston ring set and turboxs bov and dss racing custom forged piston set and pte gen2 76/75 and two pte 46mm wastegates and lunati custom ground turbo camshaft hydraulic roller
Will be just a little bit over 800hp and almost 800 lb ft of tq
Old Mar 9, 2022 | 08:54 AM
Roarin_8's Avatar
That should be dependent on your tune. If you really want to keep detonation at a minimum, run a meth/alky system.
https://ls1tech.com/forums/forced-in...turbo-faq.html
Old Mar 9, 2022 | 09:22 AM
Onbusy's Avatar
You could probably run 87 if you're just cruising around, and have a good tune. 93 octane would be fine for spirited driving. Can switch to E85 if you need a little more or if you're running too hot.
I plan on running 93 octane on my turbo 408 project.
Old Jul 28, 2022 | 12:21 AM
guillotinechef's Avatar
I've always been curious from an engine builder's / tuner's perspective on octane for LSx engines. My assumption is that the car should be tuned to desired power level for the airflow and dynamic compression ratio, but I don't know if they consider tuning a car to lets say 91 octane in the usa instead of the typical 93? With gas prices being so wild I want to save money where I can and not overspend one fuel that my engine doesnt need.
