General LSX Automobile Discussion Non-technical LSX related topics.
Engine Rust
Old Oct 2, 2006 | 09:59 AM
Coonass350's Avatar
Default Engine Rust
Can you guys help me?! i bought a 350 block and it has some rust and broke off bolts..so can somebody tell me how to get the rust off so i can start builiding it..and also about the bolts..plz help..thanks
Old Oct 2, 2006 | 10:17 AM
300bhp/ton's Avatar
eh?
I think you need to be a little more specific about where the rust is and what bolts you are talking about. I mean if the cylinder walls are rusted to buggery and the head bolts have snapped off it would be chepaer to chuck it and get another.
Pics would be a good idea
Old Oct 2, 2006 | 11:04 AM
ICRAZY6's Avatar
Well for the broken bolts you can do many things. Drill the bolt with a small drill bit and remove the broken part with an easy out. Or, you could use a torch to get it out. With the rust you could have the block bead blasted/painted/and machined. Hope this helps.
Old Oct 2, 2006 | 11:26 AM
Coonass350's Avatar
there is a pretty good bit of rust in the cylinder walls..i mean if i scrub hard enough some will come off..but it has some rust all over the engine..and the bolts are not head bolts..they are at the back and front..like where you can see the freeze plugs in the front..
Old Oct 2, 2006 | 06:50 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Check around for a parts cleaning shop. My local Napa has a parts cleaning facility that dips large parts.
Old Oct 2, 2006 | 07:06 PM
pdd's Avatar
pdd
WD40 works wonders on rusted bolts
Old Oct 3, 2006 | 03:08 AM
Coonass350's Avatar
ok thanks guys ill try that and see if it works..thanks..also would any of you guys be willing to give me a decent 350 block?? just asking
