weight differences.
weight differences.
Does anybody know right off what the difference in weight is between a 3rd generation and 4th generation Camaro? I did a search already. Thanks.
It's not that much because the third gens had a iron block and steel heads and stuf. I think the third gens are like 3300-3400, maybe a little more for the t/s with ground effects and all. The 4th gens are closer to 3500. A lot depends on the options it has and stuff, so not more then a couple hundred pounds on the high side and under a hundred(probably less) on the low side.
