General LSX Automobile Discussion Non-technical LSX related topics.
Dead cat?
Old Feb 4, 2007 | 09:55 PM
BLKWS.6's Avatar
Originally Posted by RPM WS6
That is the dumbest reply I have ever read. Talk about grasping at straws.
I'm going to bed.
No thoughts on whether or not the cat being clogged may/may NOT be the issue? I HIGHLY doubt it is a wire-problem. If it were a wire problem the code would come back ASAP, not 20 miles down the road. Right?
Old Feb 4, 2007 | 09:58 PM
Revelation Z28's Avatar
if you had EGR, you could've checked for a clogged cat by a vacuum test at the EGR valve.
go rev the car to 7k and see what comes out. maybe a hairball.
Old Feb 4, 2007 | 10:11 PM
BLKWS.6's Avatar
Okay, called my friend at the MOPAR dealership. He says negative on the clogged cat. Says that the code I have is indicative of a wiring problem and he will call his friend at the chevy dealership and get the schematics and we will go over it with a volt-meter and find out what the issue is. Arg...wiring problems scared of those.
Old Feb 4, 2007 | 10:12 PM
BLKWS.6's Avatar
Originally Posted by redramair98
if china is "superior" if i read that right then y buy a ford or gm go buy a honda moron sorry if a read that wrong cause if i read that right it stil dont make sense
Why a Honda? That comes from Japan. I think you read the quote wrong and missed the jest of it.
Old Feb 5, 2007 | 08:40 PM
JL8Jeff's Avatar
You might have a wire that got chafed somewhere and is grounding out or giving a weak signal. The 2000's have a known catalytic converter issue that is covered under warrantee and the 2001 might also, I'm not sure. Did your Mopar friend look into the cat issue? My cats smell funny after 20-30 minutes of driving so I'm waiting for them to go bad and get GM to replace them. If you really think the cat is bad, take it to a GM dealer and try to get it replaced especially since you have a code.
Old Feb 5, 2007 | 08:44 PM
BLKWS.6's Avatar
Read the fixed thread. I GOT IT
Old Feb 5, 2007 | 09:28 PM
SHINER's Avatar
Man, you car has more problems than a calculus book.
Try a search sometime.
Old Feb 5, 2007 | 09:40 PM
BaddillaK's Avatar
I think we need a new section Maybe something like "BLKWS.6's problem of the Day" that would keep this board a little clearer
j/k
