General LSX Automobile Discussion Non-technical LSX related topics.
Electrical/Relay Problem, Need Help?
Old Apr 1, 2007 | 08:44 PM
CLARKSLS1SS's Avatar
Question Electrical/Relay Problem, Need Help?
Ok here's the deal i had the rear camaro panle off earlier putting some finishing touches on it, put it all back together and moved it around ther corner, so i decide to leave about 20 mins later, i get in the car start it up and bam, no guage lights, no tail lights, no front parking lights, no license plate light, no radio, gas gauge does not work, and the tach and speedo are not working also, and when i push the truck button inside the car or on my key fob neither one will open the rear hatch, i have to use the key, so is there a relay that shorted out or what might be the problem or fix? Thanks
Ben
Old Apr 2, 2007 | 01:18 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Theres a repair and maintenence section that you should be posting this question in. You'd probably get more and better responce's if you posted this there.
Old Apr 2, 2007 | 02:02 PM
VIP1's Avatar
Copy & Paste Moderator
The Stereo & Electronics section is a good place for this as well.
Old Apr 2, 2007 | 06:23 PM
autotrix's Avatar
Closed ex-Sponsor Account
Perhaps you knocked a ground loose?? A multiple electrical problem is most likely caused by bad 'shared' connection.
