General LSX Automobile Discussion Non-technical LSX related topics.
Help! Charging Problem
Old Oct 6, 2007 | 08:13 AM
WS SIKZ's Avatar
Default Help! Charging Problem
i was on rt 3 in clifton. im diriving and check gauges comes on. i look at the battary gage it was dropping from like a lil over the middle mark , 13 all the way to nothing at all, just was dropping. braught it the the parking lot barnes n noble by party city. and checked the plug it was fine in there. i jumped it the car would die instantly after i took out jumpers but hold a lil bit depending how long they were on because the battary was getting charged. the alternator was new in march but i ordered another one think it is the alternator? it did it ounce in new york went to like 12 volts so i left the second i could and i was staring at the gage the way home it was at 12 and all of a sudden it popped back up to 14
Old Oct 6, 2007 | 09:36 AM
HDNVALLEY's Avatar
That sounds like an alternator to me. New can go bad too. It should still be under warranty. Take it back where you bought it and have them check it.
Old Oct 6, 2007 | 09:44 AM
stoverz28's Avatar
if its not the alternator check your cables expecially the power cable, they can get corrosion in them and not conduct as they should.
Old Oct 6, 2007 | 10:21 AM
matthewjernigan's Avatar
sounds like alternator
Old Oct 7, 2007 | 05:08 PM
transam5.7lt1's Avatar
Check the little wire that goes in the plug for the voltage regulator, it might be broken or loose somewhere else, follow it, it goes thru up the way by the intake manifold, mine broke there and it would show a no charge condition. Finally it came also loose at the plug, some how it heated and jumped to one of the other therminals in the regulator, it would overcharged the system, gauge needle would spike up to the max, dash lights would go bright as LEDS!!!!!!!! I just stopped and replaced alternator since the regulator got damaged, I have a reman unit with a lifetime warranty now, it works good, but when I am at a stop for too long(more than a minute!) gauge would read under half the gauge, at the orange zone. It is weird why GM put 102 amp alternators in cars such as ours that have almost everything power... even LT1s had a 140 amp alternators......
Old Oct 7, 2007 | 05:22 PM
EarlSS's Avatar
Sounds like your alternator is on its way out. Mines also on its way out i think because my gauge reads a lil over 13 sometimes but then at times its down below 13 right against the red. My alternator also smells like an electrical fire sometimes. I'm for sure fixin to get me another one.
Old Oct 7, 2007 | 05:26 PM
Mine has been on the car for about two months and it has read like that since I installed it. I wonder if the load of our cars demand is too much for a 102 amp alternator.
Old Oct 7, 2007 | 05:31 PM
EarlSS's Avatar
I'm not sure if the 102 amp is to small or not but i dont think a bigger one would hurt.
