General LSX Automobile Discussion Non-technical LSX related topics.
Disable codes??
Old Nov 26, 2007 | 09:18 AM
Ryans_pewter_ss's Avatar
Default can't pass emissions!!
I have an 02' ss with longtube headers and tsp true duals with o2 sims, no codes showing but when they try to inspect it it says the secondary air not ready and heated oxygen sensor not ready, I looked at the air pump and the hoses were kinked, any suggestions on what to do?? got less than 30 days to fix it now or state fines me. Thanks!!
Old Nov 26, 2007 | 09:24 AM
FNQUIKWS6's Avatar
What is saying "the secondary air not ready and heated oxygen sensor not ready?" try to go somewhere else man, as long as your ses light is off you should be ok. Or at least thats how it is where im from.
Old Nov 26, 2007 | 09:27 AM
slow1999blackz28's Avatar
Around here you can say your car is too low to go over the rollers to get into emissions then they give you a waver good for a year and you just keep doing that forever
Old Nov 26, 2007 | 09:29 AM
I went to two diff. places, said the same thing, and in nc they don't look under the car they just plug it in. Yeah it says on the printout those two are not ready.
Old Nov 26, 2007 | 09:38 AM
Hawk108's Avatar
Sorry if im getting off topic a little bit, but in MD(im from edgewater) ive just been plugged in to the OBDII and then sent on my way. I never had to get on the rollers, but im curious as to which emissions station gives you a waiver for being too low. . .mind sharing?
to the OP, is your SES light's bulb burnt out? I would just take it to autozone and see if they can read the code, then when you get the number take it to a tuner to have it deleted.
Old Nov 26, 2007 | 09:44 AM
Where could I have these codes deleted or buy something to do it with??
Old Nov 26, 2007 | 09:53 AM
Default Disable codes??
I need someone to delete my secondary air and my heated oxygen sensors so I will pass obdII emissions, I'm in NC, anything I can buy or take it somewhere?? Thanks!!
Old Nov 26, 2007 | 10:36 AM
Hawk108's Avatar
It would be better to have them deleted than to buy something and try and delete them. Look at the sponsor list to see if there are any in your area or go to the regional forums and post up asking where you could get codes deleted. I had a few codes deleted for cats and it was about $100.
BTW: where are you located? I might know of a place that could do it.
Old Nov 26, 2007 | 10:57 AM
I'm in NC, Thanks alot!!
Old Nov 26, 2007 | 11:03 AM
keliente's Avatar
Have you disconnected the battery lately? The emissions monitors need a certain amount of time to set (say a week of daily driving, idling, highway etc) otherwise they will show Not Ready. If the battery has not been disconnected lately and the car has not been tampered with, there may be a problem with one of the systems that is keeping the test from completing.
Old Nov 26, 2007 | 11:12 AM
I had the battery unhooked around 200 to 300 miles ago, Is that enough miles or does it take more?
Old Nov 26, 2007 | 11:16 AM
3.4camaro's Avatar
Go to a tuner and have him select "no error reported" for all emission codes, yet keep the "SES" box checked. This will keep all codes from coming back, and keep all your systems in the "READY" state.
It's what I did, no problems.
Old Nov 26, 2007 | 11:20 AM
I just called Hawks and they said they could delete the codes for me. Thanks alot for the help!!
Old Nov 26, 2007 | 11:59 AM
ErikElvis's Avatar
I had the same problem. Fixed all of my CEL's drove it a couple hundred miles then got it inspected. Still failed b/c the O2 heaters werent ready and something else. I got fed up and just bought HPTuners and tuned the crap out so the PCM didnt even check for em. Oh and I had O2 Sims I wonder if thats why the O2 heater sensor check doesnt ever complete.
Old Nov 26, 2007 | 03:36 PM
I think it is the o2 sims is why that doesn't pass, I talked to a place about an hour away that will delete the o2 and the secondary air for 50$
Old Nov 26, 2007 | 07:23 PM
waldershrek's Avatar
Is there a reason you have 2 threads in the same forum going on this problem?
Old Nov 27, 2007 | 08:34 AM
Sorry, delete one if ya need
Old Nov 27, 2007 | 04:22 PM
Well I'm not a mod so that won't happen but to answer your question......get a tune. Assuming the reason the light is on is because of headers.
Old Nov 27, 2007 | 10:12 PM
RE AND CHERYL's Avatar
If your car has to pass the OBD II testwhere they plug it into a computer to test it, your screwed. After you tune out the air and rear O2 sensors it will fail because the systems aren't there and should be.
Have Fun
Re'
Old Nov 27, 2007 | 10:29 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Duplicate threads merged....
