Hello and some help
BTW I have owned the Saab for 5 years and it was done me well, I would it got its money out of me
but I will be gland to see it go so I can get the car I have always wanted. Catalyst System Efficiency Below Threshold (Bank 1)
What does that mean?The catalytic converter has an oxygen sensor in front and behind it. When the vehicle is warm and running in closed loop mode, the upstream oxygen sensor waveform reading should fluctuate. The downstream O2 sensor reading should be fairly steady. Typically the P0420 code triggers the Check Engine Light if the readings of the two sensors are similar. This is indicative of (among other things) a converter that is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
Hope this helps!!
