Sponsored by: CARiD
WTB Power Antenna
Old Oct 14, 2008 | 12:00 PM
Firehawk526's Avatar
Default WTB Power Antenna
I found one locally for $75 (2000), but if any one else has one looking to get rid of, let me know please SOON!
Old Oct 14, 2008 | 12:14 PM
2002_Z28_Six_Speed's Avatar
What do you mean by the (2000)? Are you inferring that is it used off a 2000 car?
If so they aren't much more to buy new...
Old Oct 14, 2008 | 12:16 PM
Yes, but a NEW one is $185 from GM ($205 retail), but I also found one Delco New from Monster Parts for $132 shipped.
$75 is isn't too bad, but thought I could help out someone on the boards.
Thanks
Old Oct 15, 2008 | 12:41 PM
95TAJade's Avatar
You should be able to get an aftermarket replacement/NEW for less than that.
Old Oct 15, 2008 | 01:40 PM
One would think, but so far, $75 and $100 are the best prices I've found so far!
Old Oct 15, 2008 | 03:09 PM
wssix99's Avatar
Save the manuals!
If you just have a problem with a stuck mast on the original unit, you can get a replacement: https://ls1tech.com/forums/general-maintenance-repairs/918383-busted-my-power-antenna.html (I think gmpartsdirect has the best price but they take several weeks to deliver.)
There is also a FREE fix if the mast isn't too bad off and the motor is still working. If the mast is working half-way, you can rub it down with mineral spirits a couple of times and then work the mechanism. (Use the real stuff - not paint thinner.) A common issue with the mast is paint shedding off the metal and gumming up the joints. The mineral spirits will often disolve the goo and will get it working again. (This is a fix listed in the GM factory manual.)
I've found that road salt tends to make the situation worse and I usuually have to do the "free" proceedure every year or so. (less frequently with a new mast) Eventually, the antenna gods will win and I'll have to go for a new mast. Over 10 years, I've had to replace the mast twice, but the motor unit is still going strong.
Old Oct 15, 2008 | 03:32 PM
I got a power ant from gm a couple of years back and I know I didn't pay 180 for it. gm must of jacked up the price alot.
