Sponsored by: CARiD
Coolant issues
Old Nov 6, 2008 | 10:58 PM
LS6427's Avatar
Originally Posted by Formulals187
the cap should be brand new, and had the car idle at operating temp today and rolled around under there and there was nothing leaking
should be a new cap???? what?
The only way for coolant to get into your overflow reservoir is from having too much pressure in the radiator. It has to push the cap seal open. Try another cap.
Old Nov 6, 2008 | 11:08 PM
Formulals187's Avatar
by should be new, i just bought it from a dealership last week
Old Nov 6, 2008 | 11:31 PM
RevGTO's Avatar
Pontiacerator
Go back to the original suggestion: get a pressure check done. Then you'll know if it's leaking or not, and if it is, you can begin to try to figure out where. If not, somehow you're failing to get all the air out of the system.
Replacing the radiator cap was a good step. You've checked for visible leaks and found none. Now it's time for the pressure check. Without one, you're just going to be groping around in the dark.
Old Nov 6, 2008 | 11:33 PM
how/where do i get a pressure check done
Old Nov 6, 2008 | 11:37 PM
LS6427's Avatar
Pretty much any auto repair shop can do a pressure check. I think they charge like $15.00 at a place near me.
If you don't see any leaks, just beware: If it is a small blown head gasket leak you could be filling a cylinder with coolant as you do the pressure check. If that happens and you don't know it, and you start the engine when you're done, you could permanentely damage your engine. Hydralock. Only way to be sure is to take all 8 spark plugs out when you do the pressure check.
Old Nov 7, 2008 | 05:18 PM
Formula413's Avatar
Originally Posted by LS6427
I'd put it on a lift after its up to temp, and after topping the coolant off, and with a flashlight look for leaks all around the plastic part of the radiator and hoses. You could have a hairline leak that would be friggin hard to see just be looking under the car.
As you cool the pressure rises a little in the coolant system, then it begins to drop off slowly. Maybe it just squirts out when the pressure is climbing after you walk away.
I had this exact problem on my daily driver. Losing coolant, plenty in the tank, always low in the radiator, no puddles or visible leaks. So I finally thought to top off the radiator and then take it for a drive and look under the hood after it was warmed up. Sure enough, coolant was seeping out of the radiator through the seam between the aluminum core and the plastic tank. Replaced the radiator and all was well.
Old Nov 22, 2008 | 11:43 AM
The car hasn't ran in a week and i went out today and checked the radiator and it was about 1.5" low and i check the resiviour and the dipstick says that it should be entirely full, where is the coolant going
Old Nov 22, 2008 | 05:51 PM
and now the reading of the coolant is past the last reading on the dip stick
Old Nov 23, 2008 | 10:42 AM
wssix99's Avatar
Save the manuals!
See Formula413's post. The leak may only be apparent when the system is pressurized and up to temp. Also, you could have a bad seal at the cap due to a kink in the filler neck.
Either way, a pressure test should be able to expose where the exact problem is.
