Key will not turn
We did grab the rod and yes it moved freely forward like we where starting the car.
I went and talked to GM dealership and I was told its the rack in the column that needs to be replaced and the parts kit it only $50.00. I was told that its the slid that connects to the gear that is broke.
You want the plastic sector gear and the ign switch act.
I think the rack kit also comes with a some springs, a new 1/4 inch screw, and that weird little spring that goes into the pocket of the sector gear.
It won't be that hard to fix. I wouldn't worry about it.
If you have to replace that metal part that would suck. It is a lot harder to get the next housing off due to the pivot pins and tilt mechanism spring you have to remove. You might be able to replace the metal part without removing the next housing though.
Anyways if you get stuck let us know.
the column from the tilt to the wheel had to be removed and the Column its self was unbolted and hanging to fix the rod and the switch that connects to the cable that goes to the BTIS in the shifter.
It will be finished tomorrow afternoon, just waiting on a part from the dealership. This was a pain in the A$$!!!!!!!!
Thanks for all your help, and the pic of the column that helped alot on understanding how this all works!!!!!!!!!! Their has to be a better way, that way to much stuff in such a small area!!!
