Sponsored by: CARiD
Water pump replace questions
Old Oct 28, 2008 | 05:37 AM
ncbirdfan's Avatar
Default Water pump replace questions
I am replacing the water pump on my '01 TransAm and have a couple of questions.
Do the bolts need a sealer, anti-seize or do they go back in dry?
Also, re-use the thermostat housing 0-ring or get a new one?
Thanks in advance!
Old Oct 28, 2008 | 09:13 AM
cre81r's Avatar
usually get a new seal and don't put anything on the bolt,just torque em to specs
Old Oct 28, 2008 | 09:16 AM
WYATT318MOPAR's Avatar
I used thread sealer on my bolts, they had it when I took them out..Figuired I should put them back with it on. I have reused my thermostat o-ring before as well just don't stretch it all out when removing the stat from the housing
Old Oct 28, 2008 | 09:30 AM
97ramsst's Avatar
If it was me I would just spend the $1 of so on a new O-Ring for the T-Stat housing. It would probably be fine to reuse but its less than $2 and its cheap insurance not to have to go back in a replace (and loose coolant) if it does happen to leak.
