Power steering fluid is milky
I've done some research on this forum and people are pointing to power steering cooler. Some people even suggest removing the steering cooler all together. Will this fix my problem ? Is this recommended doing in california weather. Why not replace the power steering cooler ?
Thanks for any input
Do you guys happen to know the part number for the power steering cooler ?
Do you guys happen to know the part number for the regulare coolant hose without the power steering cooler, incase i decide to go this route ? Where can i get this hose ? GM ? Autozone ?
Thanks again
Update:
I no longer have power steering on my car. Seems like im not getting the wine sound anymore, but the power steering is completly gone. I noticed it this morning after i fired up the car and drove away. Which parts am i looking to replace now ?
P/s cooler - 5.7 liter 1998-02 w/cooler - 5.7 liter 1998-02 w/cooler
Try that
Try that
Thanks for the help.
Btw, will this give me back my power steering or is that now broken too ?
Yeah that the part...it such fix the power steering. Make sure you flush your coolant.
so i finally installed my new power steering cooler. Replaced the power steering fluid with some stuff from Autozone (valvoline) Flushed the radiator a few times, and im back at square one. The car still whines when im driving turning the wheel left / right. The power steering fluid already turned the same coffee color as before. Any other recommendation on what this problem is ?
https://ls1tech.com/forums/8818958-post10.html
This is where it will mix. There's no other spot for it to get coolant into it, so either you have old fluid in the system, or this pipe is leaking again.
A lot of air gets in there when you mess with that stuff. I think theres a couple ways to bleed the lines. The way it worked for me is I would make sure the fluid level was good. Then I would turn the car on and turn the wheel lock to lock then shut it off. If you look in the resorvoir you should see air bubbles rising out. Wait a couple mintues and repeat until the fluid looks normal. It worked for me.
