Sponsored by: CARiD
Power steering Delete
Old Nov 17, 2008 | 04:05 PM
johnnybravo's Avatar
Default Power steering Delete
Has anyone changed their power steering over to manual steering, and if so how do you like it?
I assume you would just remove the power steering pump and bracket and install a manual steering box. Anything else? Does anyone manufacture a manual steering gearbox for the newer f-bodies?
There's nothing wrong with my power steering, it just seems a bit un-natural in this type of car.
Old Nov 17, 2008 | 04:14 PM
2002_Z28_Six_Speed's Avatar
You can't really change the box. You will need to remove the power steering pump and res. Remove an alternator bolt. Get a new belt.
Then you need a manual steering rack and the adapter to run it. The manual steering rack requires that you weld a bracket on the k member.
Old Nov 17, 2008 | 05:52 PM
nemss1's Avatar
i removed the power steering pump and bracket. i removed all the lines and installed bolts to plug the holes. belt is 52.5" belt. i like how driving feels. feels like an over-powered go-cart without power steering
