Sponsored by: CARiD
HELP car wont run
Old Nov 29, 2008 | 10:02 AM
92 silverado's Avatar
Default HELP car wont run
well the car will crank and run perfect for about 3 seconds and then shut off. it was throwing a p1626 (fuel enable wire signal) so i got the bypass module from baker electronics and wired it up correctly to pin 30 on the pcm (2001 z28). i tried to start it and it ran for 3 seconds shut off and gave me that code again. the car has 60 psi fuel pressure and the fuel pump stays on the whole time. THE CAR IS DRIVING ME CRAZY HELP.
Old Nov 29, 2008 | 10:09 AM
the_merv's Avatar
Veteran: Air Force
Sounds like the Wire that comes from the PCM and activates the Fuel Pump Relay..
Old Nov 29, 2008 | 10:34 AM
it stays with fuel pressure the whole time its runnin.............i think it just cuts out injector pulse
Old Nov 29, 2008 | 10:44 AM
the_merv's Avatar
Veteran: Air Force
VATS kills power to the Injectors..
Old Nov 29, 2008 | 06:40 PM
yea and i put the bypass module on it
Old Dec 2, 2008 | 11:05 AM
i put the bypass module on it and now it has no check engine light but it still only runs for a second or two im stumped........................
