Sponsored by: CARiD
Won't Start - click click click
Old Nov 30, 2008 | 02:15 PM
TRANSdAMn 2k's Avatar
Curveball TECH
Default Won't Start - click click click
UPDATE
Looks like it is the starter, the noise is coming straight from it.
Is it okay to push start the car to the autostore and back?
I've tried searching through here but can't seem to find an answer. Here is the deal:
2000 ws6 110k miles
-When I go to crank it up all i hear is a rapid clicking noise
-Last night it did start after a couple clicks but the car would not hold an idle and just die. If i gave it gas to hold the idle up it seemed like driving was ok.
-Interior lights and headlights come on without key in ignition
thanks in advance
Old Nov 30, 2008 | 02:24 PM
wrencher's Avatar
wrencher
From the sound of it, there might be a bad connection @ the battery or a weak battery.
Old Nov 30, 2008 | 02:25 PM
LS6427's Avatar
Check the battery terminals for corrosion build up.
Interior lights and headlights should come on without the key. Mine does.
Old Nov 30, 2008 | 02:27 PM
ssman00's Avatar
also check the starter ground to the block and the starter solenoid could be bad
Old Nov 30, 2008 | 06:06 PM
Curveball TECH
Thanks for the help guys. Rode the bike to autozone picked up a starter, installed it, FIXED.
Wasn't bad at all installing that thing, but the battery was drained after i got it on and so i had to push start the bitch by myself. Then I let the battery recharge turned it off then back on and it cranked right up.
Old Nov 30, 2008 | 08:48 PM
SparkyJJO's Avatar
I'll bet it is the battery in the first place. My starter did that click click click thing it was my battery was almost dead so it could only throw the solenoid over and over, making it click.
