Sponsored by: CARiD
Replacing torque arm-trans mount
Old Dec 8, 2008 | 02:03 PM
Dave 96TA's Avatar
Default Replacing torque arm-trans mount
I hate asking dumb questions, but I've search around and found nothing. I bought a 2-piece replacement torque arm mount - the side that goes to the transmission. The stock one is out and I know I have to grind/drill the rivets out. But does the new mount need to be re-riveted? The replacement mount comes as two halves each mounted to metal plates with holes in them. This is not the one-piece kind that slips over the end of the torque arm. It looks exactly like the stock piece.
Old Dec 8, 2008 | 08:59 PM
conan's Avatar
If bolts will fit I would use 2, grade 8 bolts with lock nuts and a little blue locktite.
Old Dec 8, 2008 | 09:07 PM
Dave 96TA's Avatar
After doing a little research, it looks like almost everyone uses the one-piece design. Thinking maybe I should just hop on the wagon.
Old Dec 9, 2008 | 01:26 AM
shaun's Avatar
go to www.installuniversity.com
i think they have a write up on it maybe that would help.
Old Dec 9, 2008 | 07:23 AM
Dave 96TA's Avatar
I did before asking, they show the one-piece design.
Ordered one of those from a sponsor last night as well as some motor mounts. It's not my daily driver so I figure I'll tackle a bunch more stuff while the tranny is out.
Old Dec 9, 2008 | 07:28 AM
the_merv's Avatar
Veteran: Air Force
See if you can get some Bolts in it..
Old Dec 9, 2008 | 10:55 AM
Dave 96TA's Avatar
I'm sure I could. Or I could just tack-weld the sucker where the rivets were. But since I'm putting poly motor mounts and poly trans mount in, I figured I'll try a poly TA mount too. This two-piece feels almost like a stock rubber replacement and I can't find the details anymore on where I bought it.
Old Dec 10, 2008 | 03:12 PM
ElChiefWS602's Avatar
The Prothane T/A bushing is 2 piece. I have it on my car. I just drilled out the rivets and popped out the old rubber. I then bolted in the replacements with the supplied hardware. No clearance issues with the hardware.
Old Dec 11, 2008 | 12:05 PM
Dave 96TA's Avatar
See, I didn't get the 'supplied hardware' when I bought it from another member here.
That's OK, I'll have a spare just in case.
Old Dec 13, 2008 | 09:59 AM
HMERacing's Avatar
I have the prothane also and it is still in the package with the supplied bolts
Old Dec 13, 2008 | 10:43 AM
koolaid_kid's Avatar
The Ace hardware near me carries grade 8 bolts. Just a suggestion.
