Coolant in the Oil Cap!!!
i've been driving my car around now for a day or two, its first maiden voyage. I'm still at the monitoring stages and noticed that i had some coolant on the oil cap, i had just changed the oil and didn't notice any milk coming from the old oil. any ideas on what it could be? i checked the dipstick and the oil is still clean with no signs of coolant, no white smoke on start up and the coolant overflow was pretty much full. i did lose a little bit of coolant in the radiator but that may be due to me not fully bleeding the system. pretty stumped?!?! anyone have any ideas on this? i can't really drive it around that much because its still open headers and i've yet to get my exhaust fabbed up. Hope someone can help, its a 1999 LS1(n/a , bone stock) , Thanks!
If you drain the oil and it doesn't look milky then you should be ok. But it's definately something to keep an eye on if you are concerned.
You say you do not have a PCV system?? That is the reason you are getting this condensation in the oil cap. Are you at least running breather filters, or is the entire system closed off??
Clean the oil cap and check it every couple days to see how big the issue is. Probably nothing.
Sorry bout your new electrical problem...all the fuses good?
You have 2 options, both will work:
The ideal option is to upgrade to an LS6/L92 valley cover with integrated PCV system. You will have to grind down a casting tab in the valley to allow it to fit, but its the best system available. It will vent crankcase vapors and condensation, without sucking up lots of oil like the stock system does. You can even run a catch can to prevent any oil buildup from entering the intake.
The other option is to run breather filters. You would have to put one on each valve cover, on the nipple where the stock PCV hoses would attach to. Its also not a bad idea to get an oil cap with a breather built onto the top of it to vent the gasses up front. The problem with this system is that it doesn't provide any vacuum on the crankcase, so not all the contaminants will be removed. However, the majority of condensation and oil vapors will escape through the breathers. The other downside is that it will smell pretty bad in the summer months when its hot. Every time you stop at a light with the windows down, you get a nice whiff of oil vapor
Running with a closed off system though is a VERY bad idea. You will blow out seals (front and rear mains, valve covers, ect), sludge will build up inside the engine, and your oil will not last long at all. Acids can build up in the crankcase as a byproduct of combustion, and they can eventually eat through soft aluminum bearings and seals. Its basically a fast way to destroy the insides of your motor.
edit! found all my pcv stuff laying around and hooked it all up, should i still run a breather to this?
Basically, just keep an eye on your oil either on your dipstick or when you do an oil change. You should be fine though.
Glad to hear that you found your electrical problem too.
http://www.speedinc.com/catagory.cfm?catagory=Engine
eeeek, what a pain
